DRP Motorsports
Had A Few Stangs
- Thread starter
- #1
DRP Motorsports is now selling Steeda Autosports performance products for your 24+ S650 Mustang!
For more information click the link below
https://drpmotorsports.com/products/steeda-mustang-billet-aluminum-vertical-links-with-delrin-bushings-555-4121-2015-2024
These Steeda S550/S650 Mustang Billet Aluminum Vertical Links for 2015+ Mustang GT, EcoBoost, and V6 are made from 6061, aircraft grade aluminum. They feature CNC machined Delrin bushings, and billet steel bushing sleeves and spacers, providing less deflection than the rubber bushings in the stock vertical links, yet does not add any NVH.
These Steeda Mustang Billet Aluminum Vertical Links for 2015+ Mustang GT, EcoBoost, and V6 will not flex under load like the stock links, and will give a better feel of the rear suspension, which helps the rest of the suspension assembly perform as it should.
Our one-piece billet design is accurate down to one-thousandth of an inch (0.001"). The S550/S650 Mustang geometry requires a precise length Vertical Link (something not possible with a welded design), as either a longer or shorter piece will drastically degrade handling and stability.
The Install for Steeda's Mustang Billet Aluminum Vertical Links for 2015+ Mustang GT, EcoBoost, and V6 is simple, and includes all necessary hardware.
Steeda Vertical Link Application recommendations:
Purchase your Steeda S550 Mustang Billet Aluminum Vertical Links for your 2015+ Mustang GT, EcoBoost, or V6 at Steeda Autosports today!
Product Benefits
Note: Fits Non-Brembo Package (single piston rear caliper) 2024+ Mustang's. If you have a Performance Pack or Brembo Package 2024+ Mustang, please see part 555-4130.
WARNING: California Residents: Cancer and Reproductive Harm; www.p65warnings.ca.gov
Installation Instructions
https://www.steeda.com/product_images/images/Instructions/555-4121-instructions.pdf
- Delrin (555-4121) : Recommended for Drag Racing & to eliminate wheel hop
- Polyurethane (555-4129) : Recommended for handling applications (Street, Road Racing, AutoX)
Product Benefits
- Reduces wheel hop
- Installs easily, with basic hand tools
- Will not flex under load
- No increase in NVH
- Made in the United States with high grade materials
