STEEDA MUSTANG BILLET ALUMINUM VERTICAL LINKS - POLYURETHANE BUSHINGS 555-4129 (2015-2024)
DRP Motorsports
Had A Few Stangs
NC
2017 GT350, 2019 GT, 2020 GT500
DRP Motorsports is now selling Steeda Autosports performance products for your 24+ S650 Mustang!
For more information click the link below
https://drpmotorsports.com/products/steeda-mustang-billet-aluminum-vertical-links-polyurethane-bushings-555-4129-2015-2024
Featuring our polyurethane bushings, Steeda's S550/S650 Mustang Billet Aluminum Vertical Links provide less deflection than the rubber bushings in the stock vertical links, but do not add any NVH.
Made from 6061 aircraft grade aluminum, these links will keep your S550/S650 wheel alignment dialed-in and help keep the power planted to the ground. The larger polyurethane bushings, combined with billet steel sleeves and spacers, offer more control through jounce and rebound while still offering plenty of compliance, causing absolutely no suspension bind or an artificial spring rate.
Our one-piece billet design is accurate down to one-thousandth of an inch (0.001"). The S550/S650 Mustang geometry requires a precise length Vertical Link (something not possible with a welded design), as a either a longer or shorter piece will drastically degrade handling and stability.
These Vertical Links are an excellent component for road racers, giving better stability under severe and high speed hard braking.
Made in the USA and backed by a limited lifetime warranty, to give your Mustang the best parts possible go with Steeda, where Speed Matters
Steeda Vertical Link Application recommendations:
  • Delrin (555-4121): Recommended for Drag Racing & to eliminate wheel hop
  • Polyurethane (555-4129): Recommended for handling applications (Street, Road Racing, AutoX)
Product Benefits:
  • Reduces wheel hop
  • Provides better handling characteristics
  • Will not flex under load
  • No increase in NVH
  • One piece billet construction for maximum strength, unlike competitor products with welded ends where cracking can occur over time due to stress risers
  • Made in the USA
  • Limited Lifetime Warranty
Note: Fits Non-Brembo Package (single piston rear caliper) 2024+ Mustang's. If you have a Performance Pack or Brembo Package 2024+ Mustang, please see part 555-4130.
WARNING: California Residents: Cancer and Reproductive Harm; www.p65warnings.ca.gov
Installation Instructions
https://www.steeda.com/product_images/images/Instructions/555-4129-instructions.pdf
