RTR Upper Grille w/ LED Air Intakes // NOW AVAILABLE!
RTR Vehicles
Concord, NC.
Mustang RTR
The RTR Upper Grille w/ LED Air Intakes is the perfect upgrade to enhance the appearance of your 2024+ Ford Mustang. Proportioned around the most direct cooling for the radiator, we reinterpreted our classic pill pattern: the variable spacing and surfacing creates a perception of movement while directing airflow more effectively. The RTR Upper Grille is expertly constructed from durable, injection-molded ASA plastic to withstand the test of time. An automotive-grade paint has been used to increase durability and UV resistance. The integrated LED accent lights add a touch of sophistication and style to your Mustang's front end.
S650 Mustang RTR Upper Grille w/ LED Air Intakes // NOW AVAILABLE! RTR-Upper-Grille-Updated-On-Car
  • Fits 2024+ Mustang EcoBoost & GT
  • DOES NOT include RTR Grille Badge
  • Functional air intakes with LED accent lighting
  • LEDs with switchback functionality
  • UV-coated accent light lenses
  • Allows for uninterrupted airflow to air intakes
  • Optional passenger side block-off plate included
  • Made from durable, injection-molded ASA plastic
  • Straight Forward Installation - No Cutting Required
  • Plug-and-play wiring harness included
S650 Mustang RTR Upper Grille w/ LED Air Intakes // NOW AVAILABLE! RTR-Upper-Grille-Updated-On-Car-2
The RTR Upper Grille w/ LED Air Intakes was designed using OEM CAD data to ensure a seamless fit and installation on 2024+ Mustang EcoBoost and Mustang GT. The highlight of this grille is the cutting-edge LED lighting system that also functions as an engine air intake, directing airflow more effectively. With its integrated switchback function, the LED intakes transition seamlessly from a crisp cool white to a vibrant amber when your turn signal indicator is engaged.
S650 Mustang RTR Upper Grille w/ LED Air Intakes // NOW AVAILABLE! RunningLightvsSwitchBackLightsS650
The LED intakes are thoughtfully designed to match the factory color temperature, providing a cohesive and integrated look. The LED lenses are UV hard-coated for long-lasting durability and clarity. For a hassle-free installation, the RTR Upper Grille has a convenient plug-and-play wiring harness for the LEDs intakes, eliminating the need for complex modifications.
S650 Mustang RTR Upper Grille w/ LED Air Intakes // NOW AVAILABLE! RTR-Upper-Grille-LED-Detail
With its combination of style, functionality, and ease of installation, the RTR Upper Grille w/ LED Air Intakes is the ultimate enhancement for your 2024 Mustang’s front end. Upgrade your S650 Mustang grille today and experience the excitement that comes with owning an RTR Upper Grille.
S650 Mustang RTR Upper Grille w/ LED Air Intakes // NOW AVAILABLE! RTR-Upper-Grille-S650
To read more about the RTR Upper Grille w/ LED Air Intakes, please visit this LINK.
If you are a Mustang owner and your state or country requires you to have a front license plate installed, we have created a specialized RTR Front License Plate Bracket compatible with the RTR Upper Grille w/ LED Air Intakes. This license plate bracket is perfect for enhancing your Mustang's appearance while complying with local legal requirements.
  • Fits only Mustangs equipped with the RTR Upper Grille w/ LED Air Intakes
  • Black powder-coated finish
  • Includes all necessary hardware for installation
  • Includes soft rubber isolators to protect your paint finish
  • Made from lightweight aluminum
S650 Mustang RTR Upper Grille w/ LED Air Intakes // NOW AVAILABLE! US-Front-Plate-On-Car-With-License-Plate
S650 Mustang RTR Upper Grille w/ LED Air Intakes // NOW AVAILABLE! US-Front-Plate-On-Car-Detail
RTR Vehicles
RTR Vehicles
Concord, NC.
Mustang RTR
Check out the installation video for the RTR Upper Grille w/ LED Air Intakes!
