Rear seat removal
Gr8ful
S.Carolina
2023 Santa Cruz, V-Strom 650
I would like to add seat covers to lighten up the black interior. Going with black with gray inserts. Is there a trick or technique to removing the rear seat bottom?
Thanks much
Wrinkly568
Oregon
RAM 2500
Go on you tube. Search for 2024 rear seat delete. It’ll walk you through removing the entire rear seat. Remove it, put your seat cover on, reverse the procedure, should work. Hope it helps.
Gr8ful
Gr8ful
S.Carolina
Yes thanks. I did find a video. Its straight forward. Just push in on the the 2 tabs and lift out.
