Oil Cooler Adapter to Convert Dark Horse to AN style lines and Fittings
Mod Mustang Racing
www.modularmotorsportsracing.com
Worlds Fastest & Only 5 second Coyote
This Billet MMR Adapter is perfect for switching from the factory Oil cooler lines to AN style Braided Lines. This part bolts right on to the factory oil filter adapter for a simple installation
Features:
Great for 2016+ Shelby GT350/R , Mach One, Darkhorse and GT500 Engines swaps
Easily Plumb aftermarket / upgraded oil coolers
Double O ringed fittings insure a leak free Seal
Accepts AN-10 Fittings (not included)
Perfect for plumbing GT350/R, Darkhorse & GT500 Crate engine
Purchase here: https://www.modularmotorsportsracin...e=product_info&cPath=4_30_49&products_id=1464
For the Oil Cooler to AN Adapter fittings see MMR PN#777377
Paul's stable
Maple Ridge BC Canada
Features:
Does this cool oil better than the factory lines? What are the benefits of this set up other than looking cool?
Paul's stable
Better connection than the factory lines
Run your own custom lines
Connect to an aftermarket cooler
I understand what it does. I'm just curious to real world benefit over the stock DH cooler and lines. Do the lines make it cool better? Do they flow more oil? Just seems like a lot of money for something that is already being achieved by the OEM lines. I know it will look cool and give you some flex I guess. I have not heard of any failures of the OEM lines. Know that being said I wish they had these for the diff cooler as mine has developed a leak at the fitting and I am weighting for new line set to come in.
No reason to buy them if you have a factory cooler. Cant use them on the factory cooler anyway.
Mod Mustang Racing
Mod Mustang Racing
We have a kit for the diff pumps/coolers also.
Mod Mustang Racing
Mod Mustang Racing
I have a DH so it has the diff cooler just has a leak at the fitting going from the pump to cooler the fitting is like an A/C hose a tab with a bolt. I wish they used AN fittings.
Correct, our fitting should take care of that and convert you to AN lines, give us a call, ask for Taylor or Mark
