NEW S650 LED Sidemarkers | FORM Lighting
Status
Not open for further replies.
Form Lighting
Saint Charles, Missouri
2015+ Mustangs
S650 Mustang NEW S650 LED Sidemarkers | FORM Lighting AKJZjvN
Form Lighting is excited to introduce our LED Sidemarkers for the 2024 S650 Mustang!
If you are looking to add a more modern appearance to your Mustang, upgrading your sidemarker lamps is one of the easiest things you can do to make a big impact.
S650 Mustang NEW S650 LED Sidemarkers | FORM Lighting 8kAkd2V
Upgraded Styling. The factory lamps use just three small LEDs, barely lighting up the bottom section. With our upgrade, you get a full-length strip of LEDs that provides even, bright illumination from end to end. They are available in a smoked stealth option, a clear lens, or in an OEM red/amber color set. With these premium OE-grade replacements, you’ll stand out from the crowd with an extremely modern look.
S650 Mustang NEW S650 LED Sidemarkers | FORM Lighting weaTnUq
OEM-Grade Construction. Form Lighting sidemarkers are built with quality in mind and constructed using OEM-grade materials, including a UV-coated polycarbonate lens, automotive-grade LEDs and optics, and direct-fit connectors. Unlike other options on the market, each lamp features transient protection which prevents voltage spikes on the circuit board, ensuring long-term reliability. While they may not be the cheapest option on the market, the fit and finish of our lamps are superior to other aftermarket units.
S650 Mustang NEW S650 LED Sidemarkers | FORM Lighting j3EYcFb
Plug-and-Play. Our LED side markers for the S650 Mustang are completely plug-and play and will fit perfectly, without any body gaps. Simply take the factory housing out and reinstall. They were designed to plug into your factory connector, with no additional wiring needed. Plus, you still retain the stock retro-reflector functionality, so you’re not giving anything up—you’re just giving it the look it needed from the factory.
Click the video below to see HOW to install our 2024 Ford Mustang S650 LED Sidemarker Lights!
S650 Mustang NEW S650 LED Sidemarkers | FORM Lighting oKHiGsr
Two-Year Warranty. All Form Lighting products are rigorously tested for reliability, and backed by a two-year warranty. The warranty is supported directly by Form Lighting, and any replacement parts, if needed, are shipped quickly from Form Lighting’s US warehouse. On the rare occasion that you may need to utilize your warranty, we try to keep the process as simple as possible - for example, no return is normally necessary.
Click HERE to check out our 2024 Ford Mustang LED Accent Lights!
Do you have additional questions? We’ll be happy to help!
• Reply to this thread
• Send us a direct message
• Email: [email protected]
Are you a US forum member? DM us for a FREE shipping code!
Logan Z.
Form Lighting
Status
