FORM LIGHTING Install Tips
Sig Oris
Western Maine
If you're taking advantage of FORM LIGHTING sale this weekend, do yourself a favor and order & install the following at the same time as you have to remove the same hardware and access covers. Pay Once & Cry Once.
Also, when R&Ring the Rear Reflectors, you need a 10mm wrench and I recommend an Ignition Size Wrench as theres not much room to work. My nut was cover with Undercoating and was hard to find. Also, I didn't reuse that nut for the install. I used a generous piece of Gorilla double sided tape near the pin where you'd have to reuse the nut. You'll understand if you buy these.
Lastly, the plugs needed to tap into for the 4th Brake Light are located on the very back of the trunk. DS plug is located behind a Silver Module and PS required me removing the Sub Woofer.
https://www.formlights.com/2024-2025-ford-mustang-led-sidemarkers-set.html
https://www.formlights.com/2024-2025-ford-mustang-led-rear-reflectors-set.html
https://www.formlights.com/2024-2025-ford-mustang-led-reverse-lamp-with-4th-brake-light.html
OH, might as well install these too as you're removing the same hardware for above.
https://www.topflightautomotive.com...ront-rear-mud-flaps-matte-black-set-of-4-eos/
