Controlling AC
Ike
Louisiana
2016 Mustang GT, 2024 Mustang Dark Horse
Is there a setting that can turn off the AC when I turn off the AC on the display? In the mornings especially, even with the AC turned "off", the AC may still run. I like to just run the fan sometimes without the AC running, and I've always run the fan for a few minutes before turning off to help dry out the coil.
Farmer Fran
2024 GT Premium Vert
Are you sure it is not on Auto? If not something might be wrong. Mine turns off when I turn it off. I also air mine out.
EDIT... turn of AC button. go to the main temp screen. Click face or feet or both. Go to fan and set a speed. This should be in manual mode and no AC
Ike
Louisiana
Thanks. Definitely not in auto mode. I was thinking that perhaps there was a humdistat that keeps it on above a certain relative humidity as it overides the AC setting more in the morning. Guess I will need to bring it in to have the dealer look at it.
A/C on unexpectedly - stealership updated
TL;DR - Your Mustang decides when to run the AC, not you.
