Black Friday 2024 at Lethal Performance has BEGUN!
JakeLethal
Wellington, FL
2022 F-150 RCSB 5.0
Good Morning, #teamlethal fans and welcome to Black Friday sales 2024 at Lethal Performance!
IT'S SHOWTIME!
We're kicking things off with some big savings on your favorite brands, like Mcleod Racing, 1320Junkie Ported Manifolds, Thermal R&D, CVFabrication, Kooks Headers, and a bunch of Lethal Performance brand items, like our Cobra Crank Support, LPS5 Drag Wheels, Explorer ST Catbacks, and much more still to come.
What's active RIGHT NOW!
S650 Mustang Black Friday 2024 at Lethal Performance has BEGUN! general
If that's not enough, we're also giving away a $2500 Gift Card shipping spree to the website!
TO ENTER:
To enter, just grab a lethalperformance.com gift card. Every $10 in gift cards that you purchase is 1 entry (so for example, a $500 gift card is equal to 50 entries). Our gift cards do not expire so you do not have to spend them immediately and there is no limit to how much you can buy.
CLICK HERE to grab a card!
S650 Mustang Black Friday 2024 at Lethal Performance has BEGUN! giftcardgiveaway (3)
Check out all of our Black Friday Sales here --> BLACK FRIDAY AT LETHAL PERFORMANCE STARTS NOW!
PLUS, our F-150 Giveaway is LIVE! Every $1 spent here at Lethal Performance until December 31st, 2024 gets you an entry for a chance to take home the ultimate upgrade - a Whipple Supercharged 2022 F150 and $15,000 cash!
https://www.lethalperformance.com/info/teamlethal-f150-giveaway
LethalPerformance
Fl
Hey Mustang Owners!
The first sale on our lineup to highlight is going to be Mcleod! Starting now, until 11/18/24, enjoy 20% OFF Mcleod clutches and more here at Lethal Performance.
If you want to upgrade the performance of your clutch to handle the power of your build, Mcleod has you covered.
Check out our line up below:
SHOP NOW | Mcleod Mustang
Always feel free to reach out to any one of us here at Lethal Performance if you have any questions!
S650 Mustang Black Friday 2024 at Lethal Performance has BEGUN! McLeod (3)
TO ENTER:
JakeLethal
JakeLethal
Wellington, FL
2022 F-150 RCSB 5.0
IT'S SHOWTIME!
TO ENTER:
Hey Guys! Next sale to highlight is none other than our very own Kooks headers collaboration!
Our Lethal Performance by Kooks 1-7/8 Headers & Competition Only Connection Kit (2015-2024 Mustang GT 5.0L) are on SALE right now for $1,399 SHIPPED!
Featuring:
1 7/8" x 3" Stainless Steel Long Tube Headers
Includes Stainless Steel Off Road Connection Pipes for OEM Cat Back Connection
All O2 Bungs And Emissions Components Installed
All Hardware Required For Install Is Included
These products are not legal for sale, installation, or use on licensed vehicle in the state of California. And they do NOT meet CARB compliance
Grab your set in the link below!
Lethal Performance by Kooks 1-7/8 Headers & Competition Only Connection Kit (2015-2024 Mustang GT 5.0L) - 1151H412-LP
psst... don't forget. These get you DOUBLE the entries into our F-150 giveaway ;)
S650 Mustang Black Friday 2024 at Lethal Performance has BEGUN! LPbyKooksHeaders
JakeLethal
JakeLethal
Wellington, FL
2022 F-150 RCSB 5.0
Featuring:
Good Morning, #teamlethal fans out there!
It's officially day 2 of our Black Friday sales. The next one we really would like to highlight is our very own Drag Wheels!
Our LPS5 wheels right now are up to 20% OFF right now! Ends 12/2
  • Cast aluminum, Rotary Forged for lightweight durability.
  • Front Wheel Weight: 23.3lbs
  • Rear Wheel Weight: 25.6lbs (non beadlock) / 26.1lbs (beadlock)
  • Front spec is 18x5, -18 Offset.
  • Rear Non Beadlock spec is 17x10, +48 Offset.
  • Rear Beadlock spec is 17x10, +50 Offset.
  • Available with Beadlock for Rears.
We have confirmed fitment with base brake 05-14 Mustang GT’s, base brake & Brembo Performance Pack 15+ Mustang GT/Ecoboost cars, and base brake 2024+ Mustang GT/Ecoboost.
NOTE: Once tires are mounted, RETURNS WILL NOT BE ACCEPTED. Check fitment before mounting tires on your wheels!
Bolts for beadlock are to be tightened by hand to 25 ft/lbs in a star pattern then topped to 30 ft/lbs
Check them out in the link below:
SHOP NOW | Lethal Performance LPS5 Drag Wheels
S650 Mustang Black Friday 2024 at Lethal Performance has BEGUN! LPS5 (3)
LethalPerformance
Fl
Hey Mustang Owners!
Next on our line-up is going to be the 1320 Junkie Performance. Starting now until 11/18, get $50 OFF ported manifolds. PLUS all boost proof Boss manifolds get free 90mm porting upgrade!
All 1320 intake manifolds are new OEM units not a core off of another vehicle. Hand ported to perfection providing you optimal air flow which results in more HP and TQ!
SHOP NOW | 1320 Junkie Performance
S650 Mustang Black Friday 2024 at Lethal Performance has BEGUN! 1320manifold
JakeLethal
JakeLethal
Wellington, FL
2022 F-150 RCSB 5.0
Hey Mustang Owners!
Hey, Cobra Guys! We didn't forget about you!
Our Lethal Performance Cobra Crank Support System is $210 OFF For Black Friday! Ends 11/15, so hurry up and grab yours!
Product Features
21mm Hex on tip of mandrel to allow CW/CCW rotation of engine
Support legs indexed into main plate to eliminate any chance of plate shifting
Multi-axis support gussets that lock bottom stand offs into the pan rails to ensure the strongest and safest method of locating the bearing plate without any chance of shifting or slipping
Integrated crank ring idler, eliminating the need for other AUX systems
1/2" of diagonal pulley travel to make precise tensioner adjustments or aid in belt installation
Supports both 8 and 10 rib IW - Metco hub configurations up to 4lb Rings
Clears stock fan and all accessories.
Note: Innovator's West new style 1-piece balancers require Lethal Performance adapter option
Note: Cast Aluminum Pans may require some modification to work.
Note: Requires Innovators West Crank Pulley with Metco Hub.
Check out it out here ---> Lethal Performance Crank Support System 2003-2004 Mustang Cobra
S650 Mustang Black Friday 2024 at Lethal Performance has BEGUN! LP_CobraCrankSupport
JakeLethal
JakeLethal
Wellington, FL
2022 F-150 RCSB 5.0
Product Features
Good Morning, #teamlethal fans! Happy Friday jr!
We've launched a bunch of awesome sales this week, but we're not done!
Keep in mind, the page is constantly updating with new sales that are added as time goes on.
Make sure to keep this bookmarked!
https://www.lethalperformance.com/info/blackfriday
Also, just a reminder that we've also got a $2500 Gift Card Giveaway going on, our Whipple Supercharged F150 giveaway AND we might have one or two tricks up our sleeve ;)
As always, if you guys have any questions or need help ordering; feel free to reach to any one of us here and we'll be here to help!
S650 Mustang Black Friday 2024 at Lethal Performance has BEGUN! general (1)
JakeLethal
JakeLethal
Wellington, FL
2022 F-150 RCSB 5.0
Weld Racing Wheels has entered the chat!
From now until 12/2, save UP TO 20% off Weld Racing. No code required; just add-to-cart!
If your ride has been needing some new shoes, now's the time to grab a set!
SHOP NOW | Weld Racing Wheels Mustang
P.S. these may or may not get you DOUBLE entries into our F-150 giveaway..
S650 Mustang Black Friday 2024 at Lethal Performance has BEGUN! weld racing bf s650
JakeLethal
JakeLethal
Wellington, FL
2022 F-150 RCSB 5.0
Happy Friday, #teamlethal fans!
Right now, until 12/31; save UP TO 15% off all MRT products here at Lethal!
This includes catbacks, axlebacks, hood struts & MORE!
Check out the entire MRT catalog in the link below
SHOP NOW | MRT Engineering
S650 Mustang Black Friday 2024 at Lethal Performance has BEGUN! mrt axleback bf
JakeLethal
JakeLethal
Wellington, FL
2022 F-150 RCSB 5.0
Good Morning, #teamlethal FANS!
HAPPY MONDAY! It's a great Monday actually, because new week = new sales here at Lethal Performance!
Today, we're kicking off week two of our Black Friday sales with Kooks Headers & Exhaust!
Right now, to the 25th; enjoy 15% OFF! No code needed, just add-to-cart!
Check out our lineup in the link below:
SHOP NOW | Kooks Headers & Exhaust Mustang
psst.. Kooks gets you double entries in our F150 giveaway..
S650 Mustang Black Friday 2024 at Lethal Performance has BEGUN! Kooks (4)
LethalPerformance
Fl
Hey Mustang Owners!
Today, we kicked off our SITEWIDE Sale here at Lethal Performance. From now, until 12/2, use code FRIDAY at checkout to get 10% OFF!
This is the best time of the year to save on upgrades and parts! Make sure to keep an eye out, as we have more sales coming up!
The Code does have standard exclusions. If it does not apply to the items you are looking for, feel free to reach out to any one of us here at Lethal Performance, and we can see if we can assist in any way!
S650 Mustang Black Friday 2024 at Lethal Performance has BEGUN! Sitewide
JakeLethal
JakeLethal
Wellington, FL
2022 F-150 RCSB 5.0
More sales going this week, & next we wanna highlight none other than our PROVEN Division X Fuel Systems!
Right now; we're slashing prices 15% on these! Ends 12/2, so act now to save big & make BIG power!
Which Fuel System is right for you?
SHOP NOW | Division X Fuel Systems
S650 Mustang Black Friday 2024 at Lethal Performance has BEGUN! DXFuelSystems
LethalPerformance
Fl
Hey Everyone!
UPR joins our Black Friday Sales line-up! From now, until 12/8, get 15% OFF UPR products here at Lethal Performance!
This includes catch cans, suspension, and more! PLUS, UPR products earn you double entries into our #teamlethal F-150 Giveaway!
Check out our entire line up of Black Friday Sales below:
S650 Mustang Black Friday 2024 at Lethal Performance has BEGUN! UPRCatchCan
JakeLethal
JakeLethal
Wellington, FL
2022 F-150 RCSB 5.0
Hey Guys!
Plenty more sales on the horizon, but we can't forget what's going on right now and ending soon!
LP Cobra Crank Support - $210 OFF - Ends 11/15
Mcleod Racing - 20% OFF - Ends 11/18
1320junkie Ported Manifolds - $50 OFF - Ends 11/18
Check out all of our Black Friday Sales in the link below:
S650 Mustang Black Friday 2024 at Lethal Performance has BEGUN! McLeod (5)
LethalPerformance
Fl
Happy Friday Mustang Owners!
Before we head into the weekend, I wanted to remind you guys that our SITEWIDE Sale here at Lethal Performance is still going strong.
Checkout the rest of our Black Friday Sales HERE!
S650 Mustang Black Friday 2024 at Lethal Performance has BEGUN! Sitewide (1)
