2024 gt Wind noise from A pillar / front portion of passenger window
sbannan
Jersey city
Hey all, just picked up a 2024 gt with 7k miles, noticed pretty significant amount of wind noise coming somewhere around the A pillar or front of passenger window / side mirror (hard to pinpoint). I can't feel any air getting through however driver side is completely quiet, I've previously owned an s550 and definitely did not have this. Only occurs >40mph and sounds like the window is cracked but it looks like the window is sealed well and gaskets look fine. Taking back to the dealer, anyone else ever have something like this ? Thanks
GTSteve
Tulsa
Yes, I have. I had to have my driver side window replaced bc a gouge developed from a defective window track. When I left the dealership and got on the highway the noise was unbearably loud.
Went back to the shop for them to fix it. Upon inspection, the window appeared to be rolled up completely but in reality it wasn't. I took a business card and rolled both of the windows up with the card placed between the glass and seal to compare the amount of pressure by trying to pull the card out when windows were in the full up position. The card in the replaced driver side window could be pulled out quite easily, the passenger side took a significant amount of force to get it out.
So I suggest you try the same test to determine if your passenger side window needs to be adjusted. I'm willing to bet that you will find there is a noticeable difference between the two windows.
Hope you are able to determine the cause and have it fixed!
Frogdog1
Dixie
Nope. My Mustang is one of the quietest cars I've ever driven, sans the engine and exhaust. OP, call Houston, you have a problem.
Fusion Training Systems
ohio
2024 Ford Mustang GT
I have a 24 GT and my passenger window will slowly creep down a 1/4in or little more and can hear the wind come through.
if I open and close the passenger door the window will go back up and deal with no wind noise. Then sometimes it till come back down and sometimes it won’t.
I heard the window motor can go bad. Taking mine back to the dealership again to get fixed. The first time they reprogrammed it with not much luck.
Frogdog1
Dixie
Wear them out if necessary. You paid for a warranty if it's still in effect.
Jdio
2024 gt pp 2018 gt350 2003 cobra
its the windshield side molding
Nikujaga
2018 Ecoboost
I have the wind noise issue from an angle but only on windy days . Did you get yours fixed, if yes, what did they do to fix it? Thanks.
So what was the fix?
