about S550 / S650 KW Suspension
choi
korea
mustang s650 / aviator
Hello.
I am the owner of the Mustang 7th generation in Korea.
All Mustang vehicles imported into Korea contain MRC. However, I would like to ask you because the product for S650 MRC has not been released yet because I want to install KWV3 suspension.
As a result of inquiring with the KW German headquarters, it was not released for MRC because the test was not finished. However, when I asked BC Racing, they confirmed that they have a dark hose and have installed suspension for S550 and there is no difference.
Then, wouldn't it be okay to install a product for the S550 for the KW suspension?
Does anyone know if the suspension on the S550 and S650 is compatible?
kagemusha2662
Idk
Hello.
I’ve looked into this and from what I understand, it should be pretty similar except the rear control arm of the pre refresh s550 and the post refresh s550 Are different so you’d have to check to see which coilovers fit which one of those. I’d assume that coilovers that fit the post refresh s550 should fit the s650 no problem. As far as MRC goes, when installing any coilovers you’d have to get the mag delete kit from either the coilover manufacturer or from somewhere like MagDelete
choi
korea
Thank you for your detailed answer.
I'm going to buy a product with magdelete among kw products.
There have been no cases of suspension replacement in Korea yet, so I'm going to try it for the first time. If I succeed, I will definitely post it.
