tj@steeda
2015 Steeda Mustang
While it's obvious on the outside what's changed with the S650, there are a few key things underneath that set it apart from the S550. One of those is the front control arms, referred to as lateral & tension links, and they've been updated for the 2024. These arms provide not only weight savings over the S550 but also suspension geometry fixes.
If you want to know more or get your S650 dialed in, give our staff a call at 1800 950 0774!
Dave2013M3
El Segundo,Ca
Can the S650 parts be used in the S550?
tj@steeda
tj@steeda
2015 Steeda Mustang
Based on my understanding & watching the video, if you own an S550, you can directly use S650 lateral links, tension links, ball joint kits, and spherical bearing kits.
Give our team a call at 1800 950 0774 if we can assist further!
Best,
TJ
tj@steeda
tj@steeda
2015 Steeda Mustang
We'll have an article coming out, too.
Best,
TJ
